3m masking
Some parts i did last night(only took about 6 beers).Ran 5 pieces the same size 1/4 x 1 1/2 x 9 1/2 and a shifter off a suzuki(about the same size. cast).Been using a 225 amp charger with a dimmer.1 - 3 acid ratio,15 gal tank.Set it to about 16.6 volts which put the amps at about 10 and ran for 90 minutes.Dried with compressed air and masked with 3m plastic tape that i got at an auto paint store.Worked pretty good,stayed on ,didnt leech under and peeled easy when done.
