Thread: Pore preserving
Old 04-21-2006, 10:28 PM
buckeyevs buckeyevs is offline
buckeyevs
Default Pore preserving
I have a project coming up in which there are basically two parts that need to be dyed simultaneously to achieve a matching fade. The large surface area and small power supply prohibit simultaneous anodizing. I have read that being let in the atmosphere will start to seal the pores naturally. If this is true is there any way to anodize one part and preserve the pore structure until the second part is finished anodizing and ready for the dye? My system follows.
6/2amp manual battery charger.
CV setup.
Cleaner/degreaser, etch, cleaner/degreaser, desmut, anodize, 140* dye, high temp sealer.
Can I possibly manage this or will I need to get a bigger power supply and anodizing tank in order to be successful?
As a side question, is there any pointers one can give for calculating the surface area of very irregular pieces. A decoratively cut paintball marker is the object in question.
Thanks for any tips you can provide.
