I am restoring a 1981 Yamaha 850 and wish to plate some of the parts. I plan to use Electroless Krome. My biggest concern is not knowing what type of metal the parts are made of and ruining a batch of electroless krome solution. The Aluminun parts can be zincated and then plated with electroless krome, correct? Is it safe to assume that if a part is not alluminum and does not react to acid, then that part can be safely put in the electroless krome solution? If a part reacts to acid is it safe to then flash copper? I have read much of the forum and everyone speaks of the reaction of acid to pot metal, zinc, etc. If using muriatic acid how quick will this reaction be? I plan to puchase the flash copper and electroless krome kits. Any help would be greatly appreciated
