Originally Posted by termite11
I have used the oven a couple of times and found they work but you do need air flow over them or they will have a short life.
How much airflow
I planning a 4 X 8 X 4 oven with a squirrel cage circulation fan (not fresh ail), how many CFM will I be needed with the coil style element?
The elements will be mounted in the exhaust side of the ail flow.
