Old 04-24-2006, 02:09 AM
zazzn zazzn is offline
zazzn is on a distinguished road
Default Re: Newbie polish questions already saw the FAQ on caswell
Here are the sepcs on my 6" grinder (using 8" polishing discs)
Fully balanced, 1 medium and 1 coarse grinding wheel for a variety of dry applications
Two heavy-duty eye shields to protect the operator from injury
A gooseneck-style lamp to provide light on to the item being grounded - bulb not included
Rear exhaust chutes direct debris away from operator
Cast-iron base and motor housing to reduce vibration and increase stability
3.5A ball-bearing motor provides 1/2-hp for a no load speed of 3,450 rpm
14½ x 8 x 17" d (37 x 20.4 x 43.2cm d)
The sepcs on my new 8" grinder is below however, they use 1/2" arms instead of 5/8th so I can't use my caswell arm extensions. I was planning on returning it beucase of that.
A gooseneck style lamp to provide light on to the item being grounded - bulb not included
5A ball-bearing motor provides 1-hp for a no load speed of 3,450 rpm
16 x 10 x 18" d (40.7 x 25.4 x 45.8cm d)
