I found that if you use an old buffing wheel that the greasless compounds stick much better. also, you should not have to use the greasless coumpounds on the main part of the frame only on the lower legs where you can see that it is sand casted. That part is usually seperated by a weld. wherever there is sandcast it is harder to get a good shine, but if you spend enough time, it will look great.
