Re: first time powdering today NOW ???????S
hope this helps
1 = use 20 PSI going to the gun so that when you pull the trigger you get around 15 psi , adjust the bottom plastic screw till you get the right amount of powder and you might want to shake the gun in a small circular motion while shooting
2 = anything done to a polish surface will be seen after clear is applied
clean it as best you can , outgass and coat
3 = powder always has some wavi finish and it shows up more with hobby guns , you might want to check your ground too.
and for second coats always use the 150 rule
let part cool to 150 degres then coat , you will never have any problems
