Old 04-27-2006, 04:02 PM
mpierich mpierich is offline
Default Re: Stainless Polishing Fork Tubes
Originally Posted by EricWil
I will be polishing some stainless fork tube covers on my motorcycle and they are stainless. Currently the finish is a brushed finish and I wonder what I should start with. Stainless sounds like it is a bit harder to polish then alluminum I assume because it is a harder metal. Who has done this and how?
I would probably start with 220 (with whatever tools you have), in my case with greasless on cotton wheels and felt bobs, and perhaps cartridge rolls on a die grinder. I've used the 8" expander wheel for sliders but it takes a huge amount of patience for me to avoid getting ripples.
Then the same routine with 320, and approximately the same with emery and white compounds. I know sisal works well with emery on stainless brake rotors. Actually I prefer working on it to aluminum. It polishes just as easily, but is more forgiving, and takes on a brighter finish. Good luck.
