Re: Why does my math not jive with 720 Calculator?
Your acid concentration sounds stronger than the recommended 1:3 battery acid/water formla for LCD anodizing. The PAR calculator assumes 1:3 ratio... an electrolyte that required higher voltages to achieve the same amps.
Maybe I'm off base on that... anybody else chime in?
