Old 04-30-2006, 11:21 PM
azoldbill's Avatar
azoldbill azoldbill is offline
azoldbill is on a distinguished road
Question Newb with some candy questions.....
Hey Guys,
First off, I want to say this forum is very informative. There are a lot of active members helping us newbs out, and it sure is appreciated!
Anyhow, for fun this past Friday, I had a lid-less ammo can that I thought I'd try a candy color with. The end results were less than spectacular, but I at least now have something that I can use to test the durability of powdercoating with. Anyhow, I sprayed on some metallic silver and got a good, even coat going on that. I put it in the oven at 400* for about 15 minutes and pulled it out and let it cool down to 150*. I then sprayed a candy red over it. Almost immediately, I noticed that I wasn't getting a uniform adhesion with the red. Anyhow I did what I could and stuck it back in the oven. Basically, I ended up with a very non-uniform candy red. The bottom (which was facing up btw) came out best, the large side facing towards me came out so-so, but weak in color, the back side came out mostly pink with a bit of silver showing. Same on the small ends.
Anyways, the bottom came out good because gravity did most the work, the side facing me came out good because I got to shoot it first (still hot I think), and the rest didn't seem to stick that well, like there wasn't a good ground. (Yes, I checked, there was.)
My suspicions are that the part cooled too much, and I didn't get adhesion by virtue of the red melting to the old. Has anyone had this problem, and did you solve it by starting with a higher temp, say 200*? Could I have put it back in the oven, pulled it back out and then shot some more candy red?
FWIW, I used a "competitors" gun for the silver, and the Caswell gun for the candy red. Both powders are competitors. And yes, I'll be getting some Caswell powders as the need arises.
I'm having fun with this, and I'm looking forward to getting the hang of it well enough to start really bragging. Thanks in advance!
