Re: anodes
It is normal for pH to inch up over time with the type of nickel plating bath Caswell uses. You can lower it again with the addition of acid, contact Caswell to find out how they recommend doing this. I think leaving your anodes in solution will also raise pH as some of the nickel dissolves over time on its own.
