Re: curing
Patience is a virtue. Some view to read and learn.
A MEK rub test will tell if you have full cure. Normally if you go by the directions there won't be any problems. I overrun the cure time quite a bit with no ill effects. I have only seen a couple of posts that talked about discoloration on certain colors due to over cure but don't remember if it was due to time or temp.
I have only used Super chrome and Xtreme chrome, so I can say if there is any better.
SS
