Originally Posted by mfergel
Or should I stick with 800 grit but maybe use the black compound on a spiral sewn wheel instead?
that is what i would do. if you have the right wheel speed and pressure you can get a spiral to work just fine. or you can also try using a treated vented buff and emory for even faster cutting but without the scratching of the sisal.
