Old 05-12-2006, 11:56 AM
seanc seanc is offline
Zinc Plating Guru
Default Re: Powder not charging
I ... found a loose circuit board (the screws had not been installed to anchor it down) and another plastic box with more wires coming out of it that was potted solid.
Does anyone know what the specifications are on these hobby guns? What is the frequency and the voltage?
The circuit board is simply a small DC power supply to feed the indicator LEDs and power a relay which turns the high voltage on and off via the foot switch.
The potted black box is the HV transformer. The input to this transformer is 120v/60Hz, so unless there's some fancy circuitry inside it (very doubtful at this price point), the output is also 60Hz.
Sean
Seans Zinc Plating page
