Thread: Boat prop
Old 05-13-2006, 05:02 PM
cdaeme's Avatar
cdaeme cdaeme is offline
cdaeme is an unknown quantity at this point
Send a message via AIM to cdaeme Send a message via Yahoo to cdaeme
Default Re: Boat prop
Mach, I PC'ed a rear wheel off a Honda Goldwing that has five non removable rubber bushings inside. The wheel went through outgas basecoat clearcoat with no problems. The area was recessed so I cut a piece of high temp insualtion and taped it into the recess to help seal the direct heat from the bushing. Dont know if this will help on your prop but this wheel done fine with no signs of dammage on the bushings.
Jason
