Old 05-18-2006, 11:27 AM
fxstcguy98 fxstcguy98 is offline
Default Re: Best way to prep & plate nuts&bolts
I've tried the basket thing too and it sucked, hard to rinse too. I know you are doing copy cad and this doesn't apply, but the shaker basket isn't worth a **** in the nickel because you temp loose connection with the part and it wont plate well. When I do nuts and bolts, I thread the nuts on a wire with plastic beads in between each one. Bolts, I take a long piece of wire, and wrap once around each bolt on the threaded area usually alternating the direction of the heads for balance. When I'm finished it looks like a string of popcorn.
