  #30 (permalink)
Old 05-24-2006, 02:15 PM
pickleboy's Avatar
Default Re: Polishing tight corners. New guy.
if you cant find adhesive backed paper for your sander then i suggest (its what i use) is a can of spray glue from the craft store. it will stick the paper to the sander pad and if you only spray it on the paper lightly it is easy to peel off when worn out and is waterproof. best of luck.
