  #31 (permalink)
Old 05-25-2006, 01:36 PM
mpierich mpierich is offline
Default Re: Polishing tight corners. New guy.
Originally Posted by pickleboy
if you cant find adhesive backed paper for your sander then i suggest (its what i use) is a can of spray glue from the craft store. it will stick the paper to the sander pad and if you only spray it on the paper lightly it is easy to peel off when worn out and is waterproof. best of luck.
I been using rubber cement for that for years, pickle. I make up a bunch of precut pieces and coat them with cement and let 'em dry (don't let the treated backs touch each other), then I put cement on the sander pad and the paper is already ready to go. I use that for small 2"-3" sanding drums too so no need to buy the made sleeves (just gotta overlap the edge a little so it doesn't catch).
