  #9 (permalink)
Old 05-25-2006, 03:28 PM
Popeye Popeye is offline
Default Re: CFM needed for 4x4x6 oven?
Mike,
It is simple, only one fan motor.. but two blades. The fan motor is mounted outside the oven, shaft goes through the oven wall. One blade on the shaft is inside the oven, the other blade is on the same shaft outside the oven.
