  #14 (permalink)
Old 05-27-2006, 01:49 PM
M_D M_D is offline
M_D
Default Re: Small tank anodizing
If you insulate the tanks or buckets you are heating, it will dramatically change how easy it is to heat the solution. Use a lid with some sort of insulation also while it is not in use. Three 300W heaters will bring a 5-gallon bucket to a rolling boil. Make sure you use a circuit with enough capacity and that any extension cords are sized properly, so the heaters get enough power.
