Re: lollypop red q
So my scheduel should be strip part with aircraft stripper, clean with brake clean, sandblast, clean with brake clean, prebake, claean with brake cleaner, spray chrome, cure at 395 for 15 min once part reaches 395, then let cool to 150, spray lollypop red, cure at 395 for 15 once part reaches 395. Is this correct? If not what should the scheduel be? Should i let the part fully cure for the chrome base? That is what the caswell directions said. Do i need a prebake? I know it is a cast steel body with a interferance fit snout out of tool hardened and machined 1018. I have a tablet that i split into two colums and i make a planned spray scheduel on one side with notes, and then an actual spray scheduel used and results. So any help on these candies would really help me for the planned sprays. Also am I taking the cure temps from the parts or the ambient temp? I was taking the the temp with a IR therm. stuck in the middle away from the elements of the oven.
