Re: Bleeding colors with clear
First I'm the one that said remove tape before full cure, I have never had an issue with the rough edge. Looking at your image the Black looks Real thick!! I can see a few runs in the powder, that is why you still have the rough edges.. So no Crack here..
Now as for the powder bleeding, each time you reheat the powder it will flow a little. So by adding the clear you allowed the color to flow and mix with the clear coat.
Jim S..
