  #19 (permalink)
Old 06-02-2006, 10:08 PM
RedRiver RedRiver is offline
Default Re: Small tank anodizing
The obvious...
Smaller Tank = Less Working Solution = Less Heat Dissipation
Smaller Tank = Less Working Solution = Faster Heatup Times
Smaller Tank = Less Working Solution = Faster Cross Contamination
Smaller Tank = Less Phyiscal Space = Smaller Parts / Batches
Smaller Tank = Less Physical Space = Smaller Power Supply
Smaller Tank = Less Chemical Required = More Economical
Things to consider when working in the wife's laundry room...
- Young children/pets and chemicals NEVER mix. Avoid this at all costs!
- Moisture/heat is generated from the hot chemical baths.
- Odors can/may be produced which are apt to be circulated by the air conditioner/furnace.
- Potential damage due to mist/splashing and/or spills.
Just my $0.02
- Dan
