Old 06-05-2006, 07:00 PM
cruizer's Avatar
cruizer cruizer is offline
cruizer
Default Re: Can you figure out what I did wrong?
Originally Posted by sdold
I stopped using paint thinner because I could never be sure I had gotten it completely flushed out of the pores of the metal.
Steve
I did use a cloth, and I have always done it this way. Perhaps I should try not using paibnt thinner and using a spray was/grease remover. Thanks for the suggestion! If anything, it couldn't make things any worse!
Originally Posted by bzer1
Your results look like a set of stands I did a few months back. My problem turned out to be spraying a different powder formula over the base coat.
TGIC vs Epoxy
Hmm, i'll have to check on that!
