Old 06-09-2006, 09:49 AM
skooterbum skooterbum is offline
skooterbum is on a distinguished road
Default Re: HELP, Wiring my Oven.
hi all i am in the same situation with wiring my system. what goes where?? i have the same thermostat and have a 60amp contactor both items are labeled as 120v but 220v can be ran through the contactor. i believe that 120v is what is needed to open and close the contactor. two 120v lines run through the contactor and one line is wired as needed through the thermostat to operate the contactor. hope this makes sense. my question is has anyone figured this out and if so would you have a diagram that i could see to get my system wired. thank you in advance for any help. i would be up against a brick wall if it wasnt for this forum. ron
