Old 06-09-2006, 05:41 PM
RedRiver RedRiver is offline
Default Re: Professional Gold Color
I'm sure its probably a dye. One could achieve a near gold plate look. I would think that the best charactersitics to do so would be the 6061T6 aluminum polished a mirrior finish. Of course you would skip the etching step on the anodizing line and because its 6061T6 you could skip the desmut step as well. Anodize at a low current density and dye with one of Clariant's gold dyes (probably "Fast Gold" or "Gold S") or US Specialty Color's dyes ("Fast Gold LN"). It may also be a blend of dyes. I know when using the old Clariant AluPrint silk screening dyes if you blended 14% Yellow, 3% Red and 83% Reducer you could almost fool a jewler into believing it was gold plated (from a short distance of course).
The key is a good polished finish and the right choice of dye. But then again, I may be way off base here. As I stated above, without seeing your sample hands-on, it is difficult to tell...
I've been wrong before and will be wrong again...
My $0.02.
- Dan
View My Anodizing Line
