Re: Sodium Hydroxide (Caustic soda) Alternative
Most of the chemicals used for anodizing are dangerous, and safety measures should always be used. Stripper is no exception.
As for attacking the aluminum, here is what I do...
Clean the parts first in either lacquer thinner, or strong detergent.
Strip at no more than 70F.
Watch the parts closely, and "help" the stripper by occasionally scrubbing with a toothbrush or other means. It usually take no more than a few minutes to strip a part.
Once the parts are stripped, immediately pull them and rinse. Go straight to the de-smut step.
If you are leaving the parts in for a long time because there are stubborn areas, it's because the parts were not cleaned first (oil, grease, paint, etc. will inhibit the stripper).
