Old 06-11-2006, 06:18 PM
mpierich mpierich is offline
Default Re: Brand new buffing wheel shredding?!?
Originally Posted by chefboiali
Should I just brush the wheel with someting before I put the emery on? I'd hate to waste it..
Not sure what you want to brush on there. Hopefully you have several wheel rakes - they are sold on this site. A piece of old saw blade will work as well. Raking a new wheel will get rid of the fuzzies all at once. Of course, they might have given you a real cheap wheel, in which case it will disintegrate in short order. Use the rake every few minutes while polishing.
Have you read the manual on this site?
Also, is it a good idea to always use 5 buffing wheels at the same time? When it's spinning, it seems to handle a good amout of real estate.
Say what? ! I'd say 5 is rather excessive, but more power to you if it works. Two is the most I've tried, and I prefer one 1" wheel. Seems like 5 would be too grabby and wouldn't fit anywhere anyhow, unless you're doing big areas.
