Originally Posted by RedRiver
I have no way of knowing.
That's a bummer, I thought you had information that I didn't. So it could quite conceivably be .1° or so small as to be immeasurable outside a laboratory.
Originally Posted by cameraman
...isn't going to happen until you've anodized several hundred square feet.
Lead leeches into the solution whether you've anodized 1 square inch of surface area or 1000 square feet.
I apparently didn't explain this thoroughly enough. I said that you aren't going to try to
get rid of it until you've anodized several hundred square feet. The point is that it doesn't pose a problem until you need it to go somewhere else. Unless you're staring at an LCD screen, the CRT monitor you're looking at right now contains lead, barium, cadmium, phosphorous, and mercury. While it's sitting on your desk it isn't a problem. If you throw it in a landfill when it dies, it becomes a problem. Likewise, the lead sitting in the bottom of the tank isn't a problem while the solution is in service - and
actually, we don't even know at what rate that's happening - it's quite possible that we're only looking at 1 ppm after 1000 square feet. I don't have a rinse tank. If my ano tank ruptured, I'd clean it up.
I'm also not comfortable to hear of other people doing it. Please be responsible.
even if I neutralized it I wouldn't pour it down the sink or toss it in the alley
not much more dangerous than water... with the city, I learned that as long as the pH levels of ANY of my anodizing baths is in the 6.8-7.2 pH range... I can pour it directly into the sewer system
Well, I guess we'll just have to agree to disagree there. The only way my stuff would end up in the sewer is if the hazardous waste people put it there.
I don't mean to say that you seem like one of these people
This is making my head hurt - probably in part due to lead poisoning, I'm sure. Bottom line is you recommend Al plates, I recommend Pb plates, and it sounds like both our alleys are safe [from us].
