Old 06-17-2006, 12:54 AM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: removing metal lacquer
You can get aviation stripper. It's about the easiest way. Just check the label to make sure it won't harm alum. Most are ok but there are some brands that are pretty caustic. The other way is to sand it off. Depends on the part configuration as to how much work it will be.
SS
