Re: Fumes, Fume suppressants, and Safety stuff
Just to make a small correction and not to be nit-picking but what is coming out of the tank is not a fume but rather a very fine mist of H2SO4 laced water droplets. The same solution that is in the tank to be precise. The only reason I mention this is that it may have a bearing on your research for the proper respirator filter. I'm not sure to be honest with you but I would assume that an activated charcoal filter would do the trick. Best keep researching this though as again, I'm really unsure.
