Yeah, the laquer thinner may leave the part slightly hazy, not cloudy. If it is cloudy, you most likely still have residue on the part. If when you say the part is black, do you mean the surface has big globs of tripoli compound all over it? You probably need more pressure and speed. What setup are you using? All the compounds turn black.
