  #17 (permalink)
Old 06-20-2006, 04:56 PM
jimcarry's Avatar
jimcarry jimcarry is offline
jimcarry is on a distinguished road
Send a message via Yahoo to jimcarry
Default Re: copy chrome vs triple chrome plating
Here is my two cents
when I first started with copy chrome I used the one step process with a 3gal kit it worked very well with very few problems after playing with this kit for some time I discovered that it work best at 1 Amp per 32 sq inches I have sense moved to a larger kit and am now using copper also
flash copper gives a better surface for the copy chrome to hold onto I am now thinking of also getting acid copper and nickle baths to use a triple plate process but with copy chrome as a final as a final plate. Although it is true that in the smaller kits a nickle anode is used in the larger kit a cobalt steel anode is used and gives a much harder surface then nickle. Also due to EPA concerns
the copy chrome is much safer and accepted by the EPA standards in fact they have told me it was the best chrome substitute they had seen trying to come into this area and after looking at my MSDS they approved of what I was doing
Jim Eaton
