Old 06-25-2006, 03:42 PM
KZjim's Avatar
KZjim KZjim is offline
KZjim is on a distinguished road
Send a message via Yahoo to KZjim
Default Re: "Orange" brand gun...
i though about adding an extra hole.. but decided to try it just rotated first.. i actually had to drop the regulator psi to about 6lbs 'cause the flow was strong.. but i moved it back to 10psi and used the regulator in the handle.. just in case i needed the boost i could just twist it up...
If it jams; Force it. And if it breaks it needed replacing anyway.
I can go from 0 to "What seems to be the problem Officer?" in 3 seconds."
