Originally Posted by DougT
Questions;
How would you polish metal after heat treating?
I would try using greaseless compound then go to emery with a sisal wheel.
Can this be cleaned up with a buffing compound?
After you use the greaseless yes!
Would you use a greaseless compound?
Yes! Start with 150 then go up to 320.
Wheels to polish the "V" shaped flute?
I would try 1" treated buffs, or bigger on a Dremel. You can double stack them if need be.
John
