Originally Posted by itsallgood
The thermostat that I'm currently using in my fat oven (not pregnant, lol), will it work with 3 3100W elements?
Anyone know where I can get the fan/blade that will work for this temp, and be sufficent for my application?
the thermostat should work since in most cases the thermo is wired to control the contactor so the draw of the elements do not go through the thermo. this means it is low amp draw and basically a switch for the elements. as for the fan blade and motor. most have used setups from grainger or try mc master carr
