  #8 (permalink)
Old 07-12-2006, 09:30 AM
FreeCitizen FreeCitizen is offline
FreeCitizen is on a distinguished road
Default Re: Buffing Standard
Originally Posted by sswee
I've never seen a surface call out like that. If it is a grit call out, #300 should give between a 32 to 63 micro inch finish. Without seeing a print or knowing the fit and function of the part it is only an assumption as to what is wanted. The only way to know for sure would be to check with the engineer that drew it. If he's like some I've dealt with, he may not even know.
SS
Actually, this sort of finish is called for in the manufacture of vessels for pharmaceutical or processes where contamination is an issue. In this case, BUFF #300 is called for to reduce the likelyhood of the material sticking to the surface causing what is known as 'snakeskin'. In such applications, tons of polishing compounds is used to finish off the very large areas. The biggest we have done is 4.5 metres diameter. The reason why I pose this question here is to try and establish what is the standard that is used to gauge a particular buffing number. I don't have the standard and previous jobs were done with reference to a sample finish. But now when we have quality checks in the form of a profile stylus, we are at a lost for what the standard should be. Even the sample finish that served as our reference gave variable readings. So, anyone knowledgeable here can help?
