Re: Volts?
what does the single pipe look like after plating, and go up to 140 on your temp. Some say not to reuse a hanger but sometimes I do for a few more times. The formula that I use works for me but their are different ways of doing it. Try using a flat sheet of copper instead of the pipes, and measure it length X width X 2 for both sides and see what you get. You shouldn't have to pickle before plating with nickle, just pickle the nickle before plating with chrome if the nickle is not activated.
