Re: Forced air heater thermostat?
Pick one up from Ebay- look for a digital temp controller using a relay that you can wire the heater into. This is not the cheapest way but I haven't found a better option... I had to remove the factory installed t-stat on mine because it wouldnt work when the temp is 100 degrees outside....
