Re: Volts?
I wrapped the copper hanger wire around the tank bar twice and twisted the ends together so it is tight and ran the other end throught the pipe, made a loop, and twisted it up. Then I bent the loop to sit flat. I dont see how this would have worked once but not again. I was thinking of drilling a hole through the pipe and trying it that way.
What guage wire do you use from the bus-bars to the tank bars and anode? Do you use aligator clips or bolt the wire to the tank bar and anode? Do you wrap the tank bar or do you have bolts to tighten the hanger wire to the tank bar? The manual touches here and there on some of this but is rather vauge. I really appreciate the help fly.
THIS FORUM NEEDS MORE GUYS LIKE YOU!!!!!
