Re: consumables,copy chrome
the things you wil replace are the anodes and the brightners the crystals only need to be added if you loose the throwing power if you are purchacing a small kit you will be using a nickle anode copy chrome will go onto most metals with out any onther plate such as copper and nickle recomend copper when plating pot metal and aluminum
Jim Eaton
