Old 07-25-2006, 11:43 AM
Shaw_2112 Shaw_2112 is offline
Shaw_2112 is on a distinguished road
Default Re: why would it do that???
Originally Posted by cbrooks
Are you cleaning the previous compound from the wheel prior to using the blue and canton flannel? If you are not, then you are mixing the compounds and it would leave you with a less than high luster finish. What is the metal, aluminum? Then you may want to use the F515-6127 with a canton flannel.
Thoroughly cleaned the previous compund off each time I switched, no issues there, and yes it is aluminum.
