  #9 (permalink)
Old 08-04-2006, 10:47 AM
seanc seanc is offline
Zinc Plating Guru
Default Re: Best way to prep & plate nuts&bolts
Woody:
how do you wire it up for the power? and how often do you rotate it? i have the round buckets, so i guess i'll have to modify it a bit.
I use a stainless steel rod and dangle it in the basket on top of the parts. I've also used an old SS butter knife. Still need to figure out how to mount the electrical connection permanently though.
I figure anything around 3-6 RPM works. Haven't yet found a strong motor that slow, so I'm still turning it manually. Every 15-30 seconds I'll turn it over.
I still haven't worked out all the kinks though. Just haven't had the time since last fall.
Sean
Seans Zinc Plating page
