Old 08-21-2006, 02:26 AM
engineerscott engineerscott is offline
engineerscott is an unknown quantity at this point
Default Re: Satin Finish When Nickel Plating
Normally the way I get a satin nickel finish is that the base metal is not fully polished, i.e. you stop the polishing process before you achieve a mirror shine at the point where you are using a fairly large grit. Basically, the finish underneath the nickel will determine the finish of the nickel plate. If you polish the base metal to a mirror finish you will get a mirror finish after you plate. If you stop polishing at a satin finish on base metal you will end up with a satin finish post plating. When you polish up after plating you want to stop with a fairly rough rouge as well.
