  #29 (permalink)
Old 08-21-2006, 01:36 PM
pickleboy's Avatar
Default Re: will regular paint gun work with tech line coating
either gun will do the job as long as you have a 1.0mm or smaller tip. as for prep if you dont get the headers blasted it probably wont hold up. the surface needs to be cleaned very well as well as be roughened up so the ceramic has some place to bite into the tubing. also when blasting be sure not to use glass beads. the manufacture says specifically not to.
