Originally Posted by Nos
As for the beads your saying to use aluminum oxide ? For the cleaning part what product can i use to do a good cleaning ? When you says the part needs to be roughened up , what do you mean by that ?
thanks alot !
last time i did ceramic i used rubbing alcohol. as for roughened up the blasting will do that, and yes preffered is aluminum oxide.
