Old 08-24-2006, 04:31 AM
db_abz db_abz is offline
db_abz is on a distinguished road
Default Re: Alloy wheel polishing questions
Not having much luck finding an M14 thread adapter but I did some checking on my drill setup.
It's got a 2 speed gearbox with variable speed control as well.
Max no load speed of 3000 rpm and it runs at 810W, which I reckon means that it's 1.08HP, should be OK?
I can also get quite cheaply, $70 or so, another drill of the same spec but with a bigger 1050W motor (1.4HP).
I hope my conversion is correct because it's cheered me up a bit!
Running 6" wheels should give me a SFPM of 4500, is there ever a case where you would cut or colour at less than maximum speed?
Dave
