Re: Does anyone use the expander wheel?
For the best results on valve covers I use a die grinder ans surface preparation pads the can be bought in different grits from course to fine and work great cutting your prep time in half the also work great for removing light pitting on pot metal this tool requires a good air compressor and the pads will even remove the stubborn stretch marks on steel valve covers
Jim Eaton
