As long as your air compressor is bigger than one of those 12 volt emergency tire inflators, you should be OK. If it has a tank, you're good to go. Very little air volume is required. Regulate the pressure to between 10 and 15 lbs. There is a small adjustment knob on the handle of the gun (right near the air inlet) for making fine adjustments while dusting. I've had my kit for a couple of months, and I really like it.
Hemi-T
