Old 09-03-2006, 05:22 PM
cameraman cameraman is offline
cameraman is on a distinguished road
Default Re: At my wit' end with wire
You didn't say what amperage you're setting on your power supply. Based on the 68" length mentioned in your other post, I'm calculating 8.6 in² of surface area, so you should be using .27 amps for 4.5 amps/ft² or .18 amps for 3 amps/ft². Is that where you're at?
